Hi SAMP!
U should use Radiosity Override in Material Editor. Try to change Indirect Bump Map Scale. Set this parameter much below default. The value between 0,2-0,4 often causes ViZ to produce nice (acceptable I mean) results. Best regards.
.:: regards ::.
Wojciech Klepacki
