Old May 16th, 2008   #6 (permalink)
Tim_Tam
Finland
Default Re: higher snow with snowmaker script
An alternative to using snowmaker script would be using PFlow with Blobmesh. It doesn't require any subdivisions and adjusting thickness of accumulated snow is simply done by increasing particle size.
If you use falloff map as density by material on your position object operator. You can very easily adjust the placement of your particles to your liking.
Rgds,
Timo
Tim_Tam is offline   Reply With Quote
