Autodesk VIZ Autodesk VIZ
Old December 13th, 2006   #11 (permalink)
quizzy's Avatar
Default Re: radiosity and chrome material
well first of all that map looks disabled.
second what you should do if you are using a IES sun is to go to the radiosity dialog and you'll find physical scale, put that at the value of your sun. This will resolve your reflections..
so if your sun says 80000 (which is standard) then set your physical scale at 80000.... and render...
Michiel Quist
http://www.3idee.nl
quizzy is offline
Shadow + Radiosity ? muzzy 3ds Max 1 November 16th, 2003 07:59 AM
