Autodesk VIZ Autodesk VIZ
Old November 30th, 2006   #1 (permalink)
illyrianeye's Avatar
Name: Beni Ecen Vete
United_States  Send a message via AIM to illyrianeye
Default radiosity and chrome material
I always had this problem with radiosity and chrome metal: Chrome doesnt look like chrome anymore when i use radiosity. What is the way around this?
If i exclude it from radiosity, i get just a black rendering of the metal.
illyrianeye is offline
Old November 30th, 2006   #2 (permalink)
Name: Mohammed Aleem mmakilm
Pakistan
Default Re: radiosity and chrome material
same it happen with me when i use vray
mmakilm is offline
Old December 1st, 2006   #3 (permalink)
Does anybody have any suggestions?
Old December 2nd, 2006   #4 (permalink)
China  Send a message via MSN to batteryoperatedlettuce
have you got a picture of a real world object which closely resembles the effect you're trying to achieve?
batteryoperatedlettuce is offline
Old December 3rd, 2006   #5 (permalink)
eksg's Avatar
Name: edvard san gabriel
Bahrain
If your using raytrace,you'll definitely get a black object.
illyrianeye,try using a map instead of the usual raytrace for chrome material,I also had problem on using raytrace on radiosity before.
Look dumb,think wise!
eksg is offline
Old December 4th, 2006   #6 (permalink)
As is, its not a raytrace material. It's just a standard material with a reflection map and blur. If I rended in scanline its fine, but when used with radiosity,it looses its shine/metallic look to it.
Old December 5th, 2006   #7 (permalink)
anybody have any suggestions? anything at all?
Old December 6th, 2006   #8 (permalink)
Ok now I am desparate, anybody have any suggestions?
Old December 6th, 2006   #9 (permalink)
I think posting screenshots of what the problem is will probably help people advise you. One of the scanline material, one of the effect under vray, one of your material settings etc...
womble is offline
Old December 6th, 2006   #10 (permalink)
eksg's Avatar
Bahrain
Use this setting.The map on the reflection slot is a fresnel .
eksg is offline
Shadow + Radiosity ? muzzy 3ds Max 1 November 16th, 2003 07:59 AM
