Re: Color bleeding
Hi Ivan,
Both Justin and Jeff have given enough info to get
colour bleed to work how you want.
To be honest mental Ray works as it should when it
comes to colour bleed. If you fed the same light energy
and colour saturation into a 'real world' set up, then the
results would be pretty much the same. The trick is to
understand how colour is transfered between surfaces
by the transport of light energy, and then understand
the toolset in MR that allows you to control that process.
Regards
Bri
