Old December 16th, 2006   #11 (permalink)
AJLynn's Avatar
Default Re: highend 3d modeling nurbs on mac !
I wasn't suggesting switching - just adding one Windows PC to run one specific piece of software. A lot of companies do this - I've worked in Windows offices where a couple of graphic designers have Macs, and I know somebody who's a partner at a firm that uses Macs, he's so pro-Mac use that he's featured on Apple's web site, and he's got a couple 3D guys using Windows. It sounded like you wanted Rhino but the IT department was getting in your way.
Anyway, what I'm suggesting is that since what you really want is Rhino, you should have Rhino. (Where's Antisthenes when you need him?) I've got a Mac myself and I'd rather be using it than a Windows box, but to get the most productivity sometimes a Windows-only program is needed.
The only software I've used that does what Rhino does as well as Rhino does it is Alias Studiotools, and even that doesn't deal with DWG files as well as Rhino. Since you have Maya, and its NURBS modeiling isn't cuttin it for you - and of the all-purpose 3D programs, Maya's got the best NURBS system - then FormZ probably isn't going to cut it either. It's really more of a polygon modeler when it comes down to it, it doesn't have the kind of technology behind it that lets you do really advanced NURBS work. It sounds like you've found Cobalt works for you, so I'd suggest trying a prototype project in the demo. I'm not sure there are any Cobalt users on this forum, and there aren't even that many still using FormZ.
AJLynn is offline
Old December 18th, 2006   #12 (permalink)
1eo
back when formZ 3.0 was out, I was introduced to Rhino 3d.... I never went back to formz.
Unless they came out with something much, much better.... FormZ nurbZ can't compare the real deal
1eo is offline
Old December 29th, 2006   #13 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
somebody is deleting my threads/posts and not giving reasons
Antisthenes is offline
Old December 29th, 2006   #14 (permalink)
manta's Avatar
from which thread ?
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old December 29th, 2006   #15 (permalink)
Belgium
Thumbs down Re: highend 3d modeling nurbs on mac !
about 10 different ones. inc. this one
by 'quizzy'?, i am bringing it to the attention of the Amin with the hope this can be resolved.
Originally Posted by manta View Post
from which thread ?
Old December 30th, 2006   #16 (permalink)
If you're using Archicad, why not use the Maxonform product for Archicad?
http://www.graphisoft.com/products/a...maxonform.html
I think it does all of the great nurbs stuff you want while being PPC and Archicad compatible.
Have you looked into it?
Wm
makeArchitecture is offline
Old December 30th, 2006   #17 (permalink)
manta's Avatar
I believe that's a poly modeling solution, could be wrong though...
DESIGN FORWARD
manta is offline
Old January 11th, 2007   #18 (permalink)
stefkeB's Avatar
Belgium  Send a message via MSN to stefkeB
MaxonForm is Cinema4D. You can do some kind of Nurbs and Subdivision surfaces, but not the full Curve/Surface control that comes with a program such as Rhino. But it integrates with ArchiCAD... unlike all other solutions. And yes, OBJ import was nice to have in ArchiCAD.
Is FormZ not meant for NURBS? I never liked it enough to try it in detail.
Have you tried Concepts?
http://www.csi-concepts.com
DCC software is indeed not what you need, although Maya is said to have a good NURBS implementation.
Maya also supports T-splines:
http://www.architosh.com/news/2005-0...tsplines1.html
--- stefkeB ---
ArchiCAD 11 - Artlantis Studio 2 - VIZ 2008 - Revit 2008
P4 3.2GHz XP/Vista/Ubuntu - PowerbookG4 OSX10.4
stefkeB is offline
Old January 11th, 2007   #19 (permalink)
Frosty's Avatar
United_States  Send a message via MSN to Frosty
What about the obvious choice of modo? Nurbs based and runs OSX.
http://www.luxology.com/whatismodo/
Steve Shaw, M.Arch
www.crucialperception.com
Frosty is offline
Old January 11th, 2007   #20 (permalink)
AJLynn's Avatar
Isn't Modo polygon/subd? I tried a demo a while back and it was great but not in a Rhino/Alias Studio way.
AJLynn is offline
Boxx vs Mac RAYMOND Off Topic 14 October 2nd, 2007 05:52 PM
Mac Pro for Architectural/Interior visualization? mesht Hardware and Technical Discusions 9 November 28th, 2006 04:51 PM
Modeling Architectural Stuff !! mrdino General Discussions 21 October 4th, 2006 04:30 PM
nurbs modeling problem atp-design 3ds Max 1 September 3rd, 2006 01:26 AM
Mac for Vray???? aligrafix Hardware and Technical Discusions 13 May 28th, 2006 01:19 AM
