Thread: Moving Objects
Old June 6th, 2008   #10 (permalink)
gdrakakis
gdrakakis's Avatar
Greece  Send a message via Skype™ to gdrakakis
Default Re: Moving Objects
Originally Posted by ZFact View Post
Hi
Can this be done without having to add the 15cm to the -1003.272?
I tried holding shift down and moving up manually but it moves up at
increpments of 10. Can this be change to increments of 5? And is that
the simplest way of doing this?
hi there are 2 ways i can think of
1) just add +x in the Coords Manager.
x is the moving distance.
c4d will do the math for you.
2) click the move icon, go to Attribute Manager->Snap Settings->quantize->set the desired movement.
this will effect every movement from now on.
hth,
george
edit: sorry, i didn't see the posts above.
i got a new lazy mouse that doesn't like to scroll
gdrakakis is offline   Reply With Quote
