#21 (permalink) | |
hi rick, thanks for your valuable support and suggestions to me,... now i have launched my renders with single single frame only. because my deadline is there within this weekend. thanks again Thanks Yogesh |
#22 (permalink) | |
thanks for supporting me with your valuable suggestions. i have launched my renders with single single frames because my deadline is there within this weekend. hope it will be going good ... thanks again Thanks Yogesh |
#23 (permalink) |
I understand what is happening...... when you use "incremental" it means that vray is based in last frame calculated to aproximate the next one, and obviously after your first an last frame is not the same frame.... so, when you use incremental add or multiframe incremental, the two frames are not equaly calculated there must be a solution in vray but not discovered yet for me...
I would try some video compositing, render the first 30 or 60 frames (depending on your animation length) and the last 30 or 60 frames in single frame mode, and edit these portions of video with the flikering video using transparency or dissolve effect... |
| irradiance map.. | shikodesign2000 | VRay Render | 1 | December 16th, 2006 09:31 AM |
| Irradiance Map in animation | FlytE | VRay Render | 4 | June 21st, 2006 07:54 AM |
| Problem for irradiance map with moving camera only | yogeshwagh | VRay Render | 7 | May 28th, 2006 10:10 PM |
| Light catch map and irradiance map corrections | naominch | VRay Render | 1 | March 7th, 2006 06:21 PM |
| a simple question about irradiance map in animation ! | edward80 | VRay Render | 11 | November 1st, 2005 12:42 PM |
