Old December 27th, 2006   #1 (permalink)
yogeshwagh's Avatar
India  Send a message via MSN to yogeshwagh
Default Problem with Irradiance map multiframe incremental urgent pls help....
hi to all,
i have stucked with one problem with irradiance map calculations with multiframe incremental . I m working on the loopable animations so in my animations my 1st and last frame should be same.
when i m rendering my 1st and last frames without saving irradiance and lightcache both are coming same. but when i m saving my lightcache and irradiance maps with multiframe incremental and giving the path for both then it is giving me shadow jitters and lighting jitters.
i don't know why its happening ,..... i request you to all pls help me out in this
thanks in advance
Yogesh
yogeshwagh is offline
Old December 27th, 2006   #2 (permalink)
Brian Smith's Avatar
Default Re: Problem with Irradiance map multiframe incremental urgent pls help....
your description is a little confusing...are you network rendering?
Use 'Incremental Add to Current Map' for IR map and 'Fly-through' for LC and you shouldn't have any problems.
Brian Smith
www.3dats.com
Brian Smith is offline
Old December 27th, 2006   #3 (permalink)
yogeshwagh's Avatar
thanks brian
i will try this. i will describe u in brief,... see i am working on the loopable animations. so i have to match my lighting and all objects in my scene with the last frame means my 1st and last frame should be same no flickers in lighting or in shadows.
in my project i m moving a light source with my camera to match the lighting of 1st frame and last frame. so if i render with single frame irradiance map and single frame for lc then both the frames are totally matched.
but the problem comes when i am saving my lc with flythru and irradiance with multiframe incremental. if i render my 0th and last frame with these two lc and irradiance map saved for whole animation it won't match its giving flickers in shadows.
thanks
Yogesh
Old December 27th, 2006   #4 (permalink)
Tim Nelson's Avatar
Are you using Vray lights? If you do, you could use the "store with irradience map" option. I 'think' that would help the problem, but not totally sure.
Tim Nelson
timnelson3d.com
Tim Nelson is offline
Old December 28th, 2006   #5 (permalink)
Rick Eloy's Avatar
If I understood this correctly, your light is moving? If so, you should use single frame for LC and IrrMap.
Rick Eloy
Rick Eloy is offline
Old December 28th, 2006   #6 (permalink)
Maybe it's just me but i still don't understand the justification for animating the lights. There's no reason why you can remove flickering GI without animating the lights. You can look at an example of a 'flickerless' (?) animation setup on the insider article 'Creating Vegetation on a Large Scale - Part 2 of 2'...in the scene file we created a looping animation (that I think is what you're trying to do) and there's no flickering GI.
I like that word, flickerless! I think i'll use it more
Brian Smith
www.3dats.com
Old December 29th, 2006   #7 (permalink)
yogeshwagh's Avatar
hi brian thanks for reply,
where is that article ,.. can u pls send the link
Old December 29th, 2006   #8 (permalink)
yogeshwagh's Avatar
hi rick thanks for your reply....
i have already rendered with single frame for both lc and irr map but it gives me so many flickers in shadows. i will upload my 0th and 900th frame just see it. then only u can find my problem
please go through the attachements and give me the solution
Old December 29th, 2006   #9 (permalink)
Christopher Nichols's Avatar
You can only bake lighting (use saved IR and LC maps) if ONLY your camera is moving. If your lights or geometry changes... even if your shaders change, you will have yo do through it brute force. You sort of have no choice there. In order to make it "flickerless" you will have to use high settings. A good "universal" setting can be found here:
http://www.chaosgroup.com/forum/phpB...ic.php?t=14747
However, I have found that you can get away with somewhat lower AA settings, in 95% of the cases. 1/25 and 0.002 or so should be good, and keep your render times more reasonable.
Christopher P Nichols
Old December 29th, 2006   #10 (permalink)
Rick Eloy's Avatar
Well, Yogesh, there is a tiny difference between the two frames. It's tiny, but noticeable. Can you post your settings? From my experience, this kind of thing happens with low settings, either for LC or IrrMap. One thing that occured to me is that you are probably using the LC scale set to screen, which is likely to cause that effect in animations. If so, change it to world and render these 2 frames again to see what happens.
Rick Eloy
irradiance map.. shikodesign2000 VRay Render 1 December 16th, 2006 09:31 AM
Irradiance Map in animation FlytE VRay Render 4 June 21st, 2006 07:54 AM
Problem for irradiance map with moving camera only yogeshwagh VRay Render 7 May 28th, 2006 10:10 PM
Light catch map and irradiance map corrections naominch VRay Render 1 March 7th, 2006 06:21 PM
a simple question about irradiance map in animation ! edward80 VRay Render 11 November 1st, 2005 12:42 PM
