Re: how to maintain silicon gird in facade
You are correct, I do not understand the problem. The image looks like if you ran it at higher res with your final render image sampler settings the butt joint lines would come through, and if they didn't you could do what Nic said. Other than that I think what you'd be better off working on would be the textures - the curbs, the glass itself, the cladding, the grass...
