Old December 29th, 2006   #1 (permalink)
padhia's Avatar
Name: padhia romaniello
United_States  Send a message via Skype™ to padhia
Default Vray Proxy Question
I am using animated Onyx Storm trees in a scene. Is it necessary to use vray proxies if i want to create and render a large number of trees? Will using Onyx trees keep memory under control the same way proxies do?
thank you!
padhia is offline
Old December 29th, 2006   #2 (permalink)
Tim Nelson's Avatar
Default Re: Vray Proxy Question
Using the Onyx Treestorm will not behave the same way that Vray proxies do. You will more than like run into memory problems if you do not convert them to Vray meshes because they are still treated as regular geometry at render time. The downside of using the vray meshes is that you cannot animate them with wind.
Tim Nelson
timnelson3d.com
Tim Nelson is offline
Vray proxy... arkitech2 VRay Render 3 December 9th, 2006 01:42 AM
optimize a model...vray proxy??? akzit VRay Render 1 February 17th, 2006 10:25 AM
Vray question regarding vray Materials baldrick1 VRay Render 8 January 26th, 2006 11:08 AM
vray animation question kamikaze VRay Render 8 December 7th, 2005 01:02 PM
Vray Question mwhite VRay Render 4 February 14th, 2005 07:25 PM
