Lightscape crashed with the message "lightscape has generated errors and will be closed...". I restarted and still got the same error, the software would not open.
I uninstalled lightscape, re-installed ... still the same error.I have installed on another machine successfully, but I can't get it back onto my machine!...I'm using Windows 2k.
Try re-installing your video driver.
Oh, I forgot...to test if its the driver you should try putting the driver into standard VGA color depth--256 colors/8 bit and running LS. LS should run--looks awful but works. If that works its almost certainly your driver.
[ October 16, 2003, 11:02 AM: Message edited by: Ernest Burden ]
