Old June 16th, 2008   #8 (permalink)
pradipta
pradipta's Avatar
India  Send a message via MSN to pradipta Send a message via Yahoo to pradipta Send a message via Skype™ to pradipta
Default Re: Looking for right method for a simulation
thanks for all the comments here,
Rawlinson: yes, i also think that way. I need to get someone who is really good in RF since its a quite tricky applications but the results if done properly will be best.
amer : i tried RF couple of times since it was in version 2. But never got must used to in it. May be i couldnt get to use it in project in big way. But, its a software i would love to explore. I will see if I can manage RF in this situation.
John : you are right, I would use a much simpler low poly model to simulate the RF if I am at all using it. Then some compositing will put the final thing look good I guess.
Claudio : yes, it seem squote tough, the stakes are high, the scene can be bit complex and RF can make any system to crawl! I would prefer to have this done in somehow using RF but have to do ground work before that. The water test simulation you did, looks good.
Thanks for all the inputs here, I would now see and explore the various ideas that has croped up in m head now and will keep you all updated here...
"There is no possibility of cheating in art. It is either good or bad."
Portfolio
3DAllusions
pradipta is offline   Reply With Quote
