Name: hugolino jaulino |
hi everybody,
i have a problem when computing GI in Distributed rendering mode there are some lighter and darker buckets ramdomly in my final output I'm sure that the problem come from the interpolation of glossy reflections i want to know if there is a way to save the calcul of glossy ref it can maby help me please help me cheers |
IR map is computed in single frame mode
i'm sure (not totaly) that glossy effects causes the prob because if i uncheck glossy effects in the global switch roll-out, all is ok. i often use intepolation check-box in vray-mat, it's faster to render than the default mode for glossy refl/refr... |
#5 (permalink) | |
Name: Christopher Nichols |
Christopher P Nichols |
hi
ok try to render a still image thus i think it's good to use this option(use interpolation) i've found on vray info an interesting topic about the "use current pass samples" they said that it's in the advanced options of irmap rollout i don't find it does anybody know this option? |
| Noise reflection of blurry reflection | purnomo_adi | VRay Render | 4 | May 24th, 2006 05:47 AM |
| How to save irr map, but not render? | Timothy Saunders | VRay Render | 2 | May 23rd, 2006 12:29 PM |
| reflection without using a flat plane? | Michael Earley | 3ds Max | 7 | September 13th, 2005 04:11 PM |
| Floor reflection....again | Chris Linek | Autodesk VIZ | 4 | October 21st, 2004 08:51 PM |
| vray: no gi with reflection | virses | VRay Render | 6 | October 8th, 2004 09:25 AM |
