Old June 18th, 2008   #11 (permalink)
Limit
Default Re: GrowFX for 3ds Max 64-bit.
Hi!
2 quizzy
or if you want to render without opacity mapped bitmaps
Why? We have created specially for this standard leaves, they contain 1,2,3 etc. polygon.
Mesh parameters--> Add-->Standard leaves
We will later give examples ...
2 Chad Warner
Did anyone get this to work in Vray?
Demo Version Limitations
The 30-day trial version of GrowFX includes all features available in the registered version but with the following limitations:
- The possibility of converting to Editable Mesh is off;
- The GrowFX object can't be copied;
- You can't create more than 5 paths;
- Not rendering in VRay, finalRender, Brazil and Maxwell Render etc.
Limit is offline   Reply With Quote
