3ds Max Autodesk 3ds Max
Old January 2nd, 2007   #1 (permalink)
Vince Paske's Avatar
Default Vista 64 bit and Max 9 64 bit
Hi Everyone,
We want to set up my workstation with a VM (virtual machine) to run Vista 64 bit and Max 9 64 bit, while keeping XP 32 for all the obvious reasons. Has anyone out there tried Max 9 64 bit on Vista 64 bit? I noticed on Autodesk's site they do not list Vista as a required OS.
Vince Paske is offline
Old January 2nd, 2007   #2 (permalink)
AJLynn's Avatar
Default Re: Vista 64 bit and Max 9 64 bit
Why Vista? And why a VM? You'd be an early adopter of Vista, with all the issues you get from that, and Max9-64 runs fine on XP64. And VMs are slow... this is for what, VMWare? It's slow, it's splits your system memory, it can't access memory the host OS can't access (so you can't go above 4GB with this method), you don't get your full video card acceleration... and all this impacts Vista and Max, which both want 3D acceleration and a lot of RAM. Is there a really good reason to set it up this way?
AJLynn is offline
Old January 2nd, 2007   #3 (permalink)
Andrew,
This is why I am asking. Your questions are concerns I have thought of too, but I wanted to hear actual experiences.
Old January 2nd, 2007   #4 (permalink)
AJLynn's Avatar
I don't know much about Vista, but Max on a VM would suck. Hard. Why not just run it in XP?
AJLynn is offline
Old January 2nd, 2007   #5 (permalink)
Andrew1's Avatar
Is there actual difference of runing max on a xp 64 instead of just xp 32 bit,
I mean is there a difference in speed of for example viewports or how it handles mesh, or the adventage lays in the larger amount of memory management. Is it worth it of switching to 64 bit system regarding the so called advantage, and what would I notice the most as an improvement ?
Andrew
Yo ! Let's Pimp this up Gee !
Andrew1 is offline
Old January 2nd, 2007   #6 (permalink)
Wow, thats really negative and not very constructive. I hope other people who are new to the forums aren't intimidated.
I found out that you can actually assign the amount of memory you want to either OS, so long as its enough to run it. Until someone does tests with high-end video cards on Vista and Max, I'm reserving judgement. Who knows...maybe with a DX 10 card 3dsMax 9 will fly on Vista. Be nice Mr. Forum Moderator.
Old January 2nd, 2007   #7 (permalink)
Andrew
64-bit's primary benefit for me is the larger memory footprint. I'm sometimes asked to do visualization for aviation projects where large terrain models are necessary and the memory requirements are very large.
Old January 2nd, 2007   #8 (permalink)
Just installed Vista Ultimate 32-bit on a Cad test station, hoping to install vista-business 64-bit with max9 64-bit sometime next week and perform some test. So far, its pretty zippy, Should know more in a few days.
mtutaj is offline
Old March 22nd, 2007   #9 (permalink)
Lebanon
max 64 did not run at all on vista 64 here.
ihabkal is offline
Old March 22nd, 2007   #10 (permalink)
AJLynn's Avatar
Vista is currently unsupported, or so I've been told. I haven't tried it myself. But I'm impressed with how difficult it is to get a PC without Vista now - a colleague was looking for one the other day and between us all we could come up with was Dell refurbs and Optiplex boxes - with really limited selection of components like video cards. (One more good reason to build your own.)
AJLynn is offline
Revit Max, and Autodesk Jefferson Grigsby General Discussions 3 March 13th, 2008 09:15 AM
exporting into Max Jefferson Grigsby Autodesk Revit 2 August 5th, 2006 08:43 AM
windows 64 crazy homeless guy Hardware and Technical Discusions 19 July 27th, 2006 01:36 AM
Max for Windows Vista aligrafix 3ds Max 2 May 4th, 2006 05:55 AM
64 Bit Max 6 Vince Paske Hardware and Technical Discusions 14 February 22nd, 2004 06:26 AM
