Old June 18th, 2008   #12 (permalink)
daveb867
yep i'm with you now, i guess i've been doing that anyway, i've never really setup multiple cameras in one scene (camera in each room)
i usually just setup my light and position it where i want, and then adjust my exposure until the light levels look right.
i guess this is what you are doing just in the same scene.
i have one more question (well probably more than one - but we'll get to them later )
i have been using my digital camera to help me when it comes to exposure, it has a lot of built in presets for different scenarios, eg, moving water, sports, day, night, portrait, fireworks etc.
i was switching between the different presets to help me get exposure right, but when i check the settings on each one, the f-stop seems to be set at 2.8 regardless of which setting i choose, it only seems to be the ISO and shutter speed changing for each preset??
surely the f-stop will change aswell?????
but then again i have heard that i can leave the shutter and ISO at the same value and then just alter the f-stop????
and then i've heard i can adjust all three??
once again i'm confused
with regards to my digital camera, the setting of f2.8 means my aperture is open quite wide therefore letting a lot of light in. but i also read that the lower the f-stop number then the blurrier the image will be, unless compensated for with the other values?
