Old June 19th, 2008   #1 (permalink)
hendrix2430
Name: Khaled Haj Hussein
Default Difference between Mix and blend maps?
Hi, can anyone briefly explain the difference between using a mix modifier to a arch mat or a blend mat right away?
Say, I want to replicate a worn metal painted surface on a pot...I'd put a mix modifier to a chrome mat. In color one, a falloff for the tint, then in color two a rust map. Both controlled by a Perlin Marble map for instance. Would that work or would using a blend mat right off the bat?
If so, why?
Thanks!
Last edited by hendrix2430; June 19th, 2008 at 06:10 AM. Reason: edit, wrong phrasing
hendrix2430 is offline   Reply With Quote
