Old June 19th, 2008   #1 (permalink)
nelpiper
nelpiper's Avatar
Name: nelson fernandes
Default show maps in viewport question
Ok. when you aplly a material with a map in it, if you don't click on the "show map in the viewport button", you only going to see the color from the base material. So far so good. If you applied lots of different materials with maps applied to them and never clicked on the "show map in the viewport" button, you only going to see a bunch of coloured geometry. Is there a way to show all the maps for all geometries in just one step? I hope now I've been clear. Thanks. I'm using MAX 8 (not 2008) by the way.
nelpiper is offline   Reply With Quote
