Originally Posted by hendrix2430
Hi, can anyone briefly explain the difference between using a mix modifier to a arch mat or a blend mat right away?
To the best of my limited knowledge...
Blend is a material type that allows you to combine other material types (Ex. Standard+Matte)
Mix is particular map that allows you to combine other types of maps (Ex. Falloff+Noise).
They behave the same way, but handle different entities (map or material).
