3ds Max Autodesk 3ds Max
Old January 3rd, 2007   #1 (permalink)
Default high res problem
Hi there, I need ur help.
The thing is that when i tried to render high resolution image 12000*8000, that time one window pop up, stating the message that "CREATING BITMAP ERROR" I really dont know why it don render this resolution. its rendering upto 11000 pixels.
Please put some lights on this issuue,
I m using max8 and scanline rendering.
My pc configuration is. AMD dual core 38000. Geforce 7600 gtx, 2gb ddr ram.
Plz help me
mushir_q is offline
Old January 3rd, 2007   #2 (permalink)
manta's Avatar
Default Re: high res problem
What OS are you using ?
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old January 3rd, 2007   #3 (permalink)
chuck's Avatar
http://discussion.autodesk.com/threa...hreadID=161393
Do you have the 3gb switch in Windows enabled? Sometimes a restart will fix it too...
Chuck
chuck is offline
Old January 4th, 2007   #4 (permalink)
I am using windows xp prf. sp2.
mushir_q is offline
Old January 4th, 2007   #5 (permalink)
Chuck
Sorry dear i dont have any idea about 3gb switch in Windows .
mushir_q is offline
Old January 5th, 2007   #6 (permalink)
Name: dan dennis obido
Bahrain
im facing same problem too, same system we are using but as oyu go high res the worktime goes higher esp when rendering a 3d model...
cadmax, bahrain
cadmax is offline
Old January 5th, 2007   #7 (permalink)
kippu's Avatar
thats seriously high resolution .... you really dont have to do it so much but still if you do have to do it .... use split frame rendering into 3 or 4 parts and it will be done
www.renderviz.com
kippu is offline
Old January 5th, 2007   #8 (permalink)
manta's Avatar
Or switch to Windows X64...
DESIGN FORWARD
manta is offline
Old January 5th, 2007   #9 (permalink)
chuck's Avatar
3gb switch: http://technet.microsoft.com/en-us/l...ae443ecbf.aspx
Windows will usually only let you use 2gb of ram per application. This will let you use 3gb before it crashes...
chuck is offline
Old January 5th, 2007   #10 (permalink)
I am Still not able to get it
mushir_q is offline
ultra high res rendering STRAT General Discussions 34 May 10th, 2006 07:32 AM
need high res trees frank1331 3ds Max 7 July 20th, 2005 11:35 PM
high res brick tex with a lot of bricks DennisHolland General Discussions 8 January 14th, 2005 08:26 AM
Free texture, high res id_ivan General Discussions 3 September 9th, 2002 05:22 PM
