Re: interior swimming pool, caustics problem
ok thanks i'l look into it.
joh i notice you are based in manchester??? what sort of work do you do??? i am in manchester myself just down in bramhall.
with regards to the caustics and sky portals at the windows???
if i keep the current setup, will i need to enable caustics on the sky portal object properties also???
or i was thinkin to just use an omni above the water with diffuse unchecked, and having that as the caustic generator rather than the daylight system???
