i think you should read tutorials that comes with revit..
Originally Posted by diablo
So how do you make the spiral stairs?
Creating Spiral Staircases
Revit Architecture 2009 User's Guide >
Working with Architectural Components >
Stairs >
- Open a plan or 3D view.
- Click Modelling menu
Stairs, or on the Modelling tab of the Design Bar, click Stairs.
- Click Set Work Plane on the Design Bar to select a different work plane. See Sketching and Work Planes.
- On the Options bar, click
- In the drawing area, click to select a center point for the spiral.
- Click a start point.
- Click an end point to complete the spiral.
Completed spiral staircase
The spiral is limited to fewer than 360 degrees. If you overlap spiral runs, a warning is displayed; stringers and railings are not placed accurately.
TipTo create a spiral staircase to multiple levels, create one helix for the stairs and then copy that helix to the appropriate levels.
