Old June 20th, 2008   #3 (permalink)
daniohayon
daniohayon's Avatar
United_States  Send a message via Skype™ to daniohayon
Default Re: more than 2 maps in the checker slots
Yes. You could use Tile maps with no grout (0) and high Fade Variance. Use the tile to mix between the maps and add more levels as you need.
Check the file(mat lib). This would work for four different maps. That's where the levels of mixing come to play.
Homer Simpson: Facts are meaningless. You could use facts to prove anything that's even remotely true!
daniohayon is offline   Reply With Quote
