3ds Max Autodesk 3ds Max
Old January 6th, 2007   #1 (permalink)
Name: deiederik van veen
Netherlands
Default make a smooth hole in a face
I want to model a structure simular to this image. I have the basic 3d model done, just straight flat faces and now i'm looking for a smart way (algorithm, shader??) to get a simular effect as by this designer.
What do you guys think is a good approach, because modeling this by hand is hopeless. Would displacment/opacity maopping be the way to go? and if so how do I make sure that I get a thikker rim at the edges, or would converting the mesh to a editable poly and make use of the bridge function be a workaround (so not working with the faces, but work with the edges instead)
crz_06 is offline
Old January 6th, 2007   #2 (permalink)
eksg's Avatar
Name: edvard san gabriel
Bahrain
Default Re: make a smooth hole in a face
You can try boolean tools,though opacity map is the easiest way to make it,but yeah your right,you have to think how to make the edges thicker.
Look dumb,think wise!
eksg is offline
Old January 6th, 2007   #3 (permalink)
Koper's Avatar
Name: AdriaaN van Jaarsveld
South Africa
using a map or 2 might be the way to go!
make a map in ps of the holes (the holes being black on white & the edges sharp), then take that same map and duplacate it. On the second map select all the black holes and give them an outside glow from black to white so that it has soft edges (this will give the rounded edges).
then apply the first map in the opacity slot and the second map in the bump slot, also tick the double sided check-box so that the backfaces also render.
you also want to apply a uwv map to control where the holes are placed on the object.
Koper is offline
Old January 7th, 2007   #4 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
does not look that hard to model
try CageEdit commands after bolean the original shelled shape
Antisthenes is offline
Old January 7th, 2007   #5 (permalink)
eksg's Avatar
Bahrain
I'ved heard words about you, that when things seems to be blurry, youre the right person to make it clear.
anyway,may i ask, how is that cage edit commands work.and how can i access it?thanks.
eksg is offline
Old January 8th, 2007   #6 (permalink)
Belgium
for instance:
Old January 8th, 2007   #7 (permalink)
Fran's Avatar
Name: Frances Gainer Davey
I agree with Adriaan - for 3dsMax, his method will work the best, since you already have your basic form.
for instance:
Do you feel like crediting the person who created this tutorial?
[ETA] The little visual tutorial is by Jonah Barnett over on the Rhino Newsgroup.
- Fran
Last edited by Fran; January 8th, 2007 at 10:50 AM. Reason: Per request of Jonas Callewaert
Fran is offline
Old January 8th, 2007   #8 (permalink)
Andrew1's Avatar
Hey,
Same as above opacity map and some bump map, you could also incorporate some displacement map to add some thickness, but this relys on a third party render like vray or fr.
cheers!
Yo ! Let's Pimp this up Gee !
Andrew1 is offline
Old January 8th, 2007   #9 (permalink)
Romania
Cool Re: make a smooth hole in a face
If you have 3DS Max 9 than this job is a piece of cake. Can be done without any plugins and in a very fast manner – model just the exterior (how you like) / use Pro Booleans (included) for advanced cuts / shell modifier / Mental Ray for rendering (“round edges” without extra polygons – new feature) - http://download.autodesk.com/global/...nts_medium.mov.
That`s all and have fun with all those new and extremely powerful features.
Mihai
vizfx is offline
Old January 8th, 2007   #10 (permalink)
eksg's Avatar
Bahrain
Mihai
gosh....really.thats cool.but too bad coz we dont have it yet.we still needs to stick with our older version of max
eksg is offline
Problem making a hole in the Wall (Box) drvox 3ds Max 4 October 5th, 2006 03:44 PM
make preview problems in 3dmax7 maxkid 3ds Max 1 August 22nd, 2006 05:01 AM
maxscript - 3d face to face dummy Gleggers Scripts 2 June 7th, 2004 03:33 AM
how to make curtians , bedsheets , cloths etc.... haneet khanna Work in Progress (WIP) 2 November 3rd, 2003 05:42 AM
Modelling problem. Bevelling / Filleting a hole. Deano 3ds Max 7 September 26th, 2003 02:21 AM
