Old June 23rd, 2008   #15 (permalink)
illegalalieninbeijing
illegalalieninbeijing's Avatar
Default Re: architectural rendering
Hi,
The building itself in the rendering is great. But if you choose to photo montage it against a photo/site photo make sure it matches the obvious - color, contrast and the works. If necessary, render your subject according to the date and time when the digital photo was taken. This is very easy since you can just right click on the digital photo ( if it is a jpeg ) and look at the properties. With the proper geographical orientation, your light and shadow will at least match the digital photo you took.
The rest are my comments on the image:
1. Is that a guy pulling a luggage in the middle of the road?
2. The transition between the rendered image and photo is very obvious.
3. The scale of the car is funny. I suggest it should be recomposed.
Goodluck.
illegalalieninbeijing is offline   Reply With Quote
