Old June 25th, 2008   #2 (permalink)
Richard McCarthy
Richard McCarthy's Avatar
Default Re: Flip control on level head?
I don't think Level head can have flip control on it.
The way around it is to use parametric visiblity function to toggle it.
eg. Set up two sets of level head however you want it, select the first group > element property > graphics tab > visibility , then the button besides visibility (square button)> add parameter. Call it "Up" level head (or whatever you want), and do the same for the other group except name it "down" level head. Save the Family as family parameter as oppose to Shared parameter. Now once you start using the new level head, you can goto level head's element property menu, edit > and then select either up or down.
Don't mess with my hat !!
Richard McCarthy is offline   Reply With Quote
