Adding to the following point,
Originally Posted by Brian Bradley
...Are you rendering to an optimal resolution? I have seen some guys calculate billboard render resolutions by using a 300 dpi setting, which is waaayyy overkill for something of that size...
Here is a link to help you with your DPI, note that they mention a 14' x 48' bilboard typically uses between 2 to 20 DPI.
http://www.signindustry.com/outdoor/...gDistance.php3
Hope this helps,
S.
Edit: And another one with a bit more info...
http://www.graphic-design.com/Photos.../9807/109.html
