Old June 26th, 2008   #2 (permalink)
johnvid
Default Re: 1920x1200 pc input monitor
Hi Dave, from the cadassist technical support team, as you know you only need 1080 and not 1200, this monitor looks nice, but its aspect ratio is 16:10 not 16.9 but that shouldn't be a problem as your playback software should be able to maintain the aspect ratio of the orig movie, but you still need a graphics card that can deliver 1920x1080 or 1200 to the samsung, and you state that it will only output that over the hdmi, if the monitor has a hdmi input then you are ok, but it doesnt state it in the specs. you can get dvi to hdmi converters, and I think you can probably get them the other way round too. you can even get USB-DVI monitor dongles for driving additional monitors from your PC (not sure if they support the resolution you need though). A quick call to overclockers should be able to confirm the additional inputs of the monitor your looking at.
johnvid is offline   Reply With Quote
