Old June 26th, 2008   #15 (permalink)
daveb867
Default Re: Exposure expert needed!! Damn mrPhotographic Exposure
matt is correct
fran, the point i'm getting at is regardless of iso shutter and f-stop, if the combination you dial in for those equals an exposure value of 8, then the renders should look the same in terms of exposure. but it doesn't. try it.
dial in a combination that equals a value of 8.
then dial in another combination that equals 8 on the EV and compare the results.
and the end of the day, what MR is saying is that the image is controlled by the exposure value. therefore if the EV is 8, the images should look the same regardless of the combination of numbers dialled in for the ISO, shutter and f-stop
