Go Back   CGarchitect.com > 3D CAD SOFTWARE > Autodesk Revit
Autodesk Revit Autodesk Revit
Old January 15th, 2007   #11 (permalink)
Rn Wong's Avatar
Name: Ryan Wong Ching
Philippines  Send a message via Yahoo to Rn Wong
Default Re: Revit families
Yup, I think it will save hima lot of time if he use revit for his designs. revit is very powerful when it comes to 3d modeling and designing because the the 3d is simultaneously done when you work with the 2d. And the good side is that you can see the massing immediately and helps the designer visualize his design...it is also more user friendly, base on my experience of using it, when compared to the autocad software.... he may still use autocad for the 2d part since it is more powerful on the 2d side "I think so"..
Rn Wong is offline
Old January 15th, 2007   #12 (permalink)
manta's Avatar
Thanx for the input Ryan, but I was hoping that Revit could output the necessary DWG's, because that's what they'll need in the end...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old January 16th, 2007   #13 (permalink)
Rn Wong's Avatar
No Problem coz revit files and views can all be exported as dwg files
Rn Wong is offline
Old January 16th, 2007   #14 (permalink)
Philippines
Originally Posted by manta View Post
Hey Arnold,
I was wondering if you could help me out with a question I have, I have a friend, he's an architect/designer, he does freelance work for a couple cruiseship companies, they are constantly changing the designs,(like every couple days), so he's constantly updating all the drawings, I have urged him in the past to start using Revit, he uses Autocad, I figued since you have used it for a while now, you would know.
So here's my question, would it be a big time saver for him to use Revit, having only to make the change once and have it reflected in all the drawings, instead of autocad changing every drawing for each change, or am I over simplifying this ?
I just think he wastes alot of time doing it his way, but I want to be alittle more certain before I start bugging him again,
Thanx, Bill
Revit would definitely be a big plus for him since Revit will update every other views of the design there is this bi-directional relationship within each view and each component thus making it very powerful for updating design documents and it is done automatically by the program. However, I would emphasize that he should be aware that Revit has some limitations on free form modeling specially curvy sufaces as what you have mentioned that the use will be for a cruise project which I presumed that the main shape will involve curvilinear surfaces he might encounter some modeling issues which he might be better off drawing it in autocad.
Just my 2 centavos.
Razorback is offline
Old January 16th, 2007   #15 (permalink)
Philippines
Once you get the hang of Revit you don't really need to use autocad it can produce much easier 2d details because you can create parametric detail components out of it.
Revit can produce 2d details as easy as autocad some users who are not that familiar with Revit's detailing capabilities goes back to autocad to finalize their 2d details.
Old January 16th, 2007   #16 (permalink)
manta's Avatar
Hey guys thank you so much for the info,
tell me though, have you encountered any compatibilty issues with those .dwg files, the reason I ask is because they seem to keep changing the format, (which I don't understand, its a 2d drawing format, why would it need to be changed, but that's another story) I use DWG gateway which will import any .dwg, but I'm concerned about his clients who might be using a certain version of autocad, not nesesarily the newest one...
Thanx again, Bill
DESIGN FORWARD
manta is offline
Old January 16th, 2007   #17 (permalink)
Philippines
Thanx again, Bill
Compatibility should not be a problem, Revit can export/import dwg format from version 2000 up to 2007 unless they are using a really outdated acad v14 then that is a problem
Old July 25th, 2008   #18 (permalink)
If you are still looking for Revit Families... let me know i'll teach you everything there is to knwo about Revit Families.
revitrockstar is offline
Old July 29th, 2008   #19 (permalink)
RAYMOND's Avatar
Originally Posted by Antisthenes View Post
i just thought i would add a bit if dissent
as a BIM holdout who has tried them all in production and comes away with a very bad flavor in mouth
BYOI if what i propose
Build(bring) your own inteligence
i have not seen any creative soultions implemented in revit only stuff standardized and limmited by the set of tools it has.
bahumbug get free, design, empower yourself don't choose a tool that would have it the inverse
good grief.... do you really feel this way....
people are still saying we should not have left pencil..
r
RAYMOND is offline
Old September 4th, 2008   #20 (permalink)
RAYMOND's Avatar
savubg time, i don't think is the real issue here
its about designing and understanding space better and having linked data....
personally i haven't seen Revit save time but it probably will as we become more adjusted to it...
but seeing things in perspective view on the fly from any veiw is the wow part both for us and the client..
2d drafting just really is impossible to understand space correctly even if you have been drawing plans for decades....
I wouldn't want to sell Revit by saying it saves time but it certainly is a leap as a design tool.
r
RAYMOND is offline
Revit model in max??? akzit 3ds Max 4 March 13th, 2008 03:51 AM
Tips for Installing Autodesk Revit Building 8 using the Web Installer Richard McCarthy Autodesk Revit 2 September 27th, 2005 06:23 AM
Beginner advise needed\Max and Revit workflow One Eye King General Discussions 8 July 3rd, 2005 08:54 PM
Switching from ACAD to REVIT... akzit General Discussions 15 June 6th, 2005 11:44 AM
Revit is taking a Leap again Welcome to The API World Arnel Autodesk Revit 3 January 28th, 2005 05:59 AM
