Old January 24th, 2007   #11 (permalink)
Default Re: LSRAD problem
Forgot to say, I alo tried with eScape to megre the files, but the same thing happens also...I read one file and then select files to merge with it, eSCape start merging but then sudenly closes and terminates
Beeeee!
del82 is offline
Old January 24th, 2007   #12 (permalink)
Belgium
Originally Posted by del82 View Post
Also I reduced the quality of the ls. files so I ended up with 900 MB instead of 1 GB.
I have found that changing the 'Max.Display Texture Size' from "Unlimited" to 245*256 hugely reduces file sizes. (Found on the document Properties)
Sorry, no help with RAM stuff
Angela Giladi is offline
Old January 24th, 2007   #13 (permalink)
Angela but doest that only effect the display of the ls. file?
I could also remove the textures form the file but that doesnt do it:-(
I read few very older post here abouth people having problems with huge ls. files...
One thing that crossed my mind is that I have merged one ls. file two times and others not...so maybe thats whats cousing the problem...but then again this doesnt seem to have effect with reduced quality, small sized ls. files...
Beeeee!
del82 is offline
Old January 24th, 2007   #14 (permalink)
It could be a RAM issue. Try to send me two ls files, upload em and I'd see if I can merge em.
_ _ ______________ _ _
Arnold Gallardo
Visual Content Creator
Technical Writer
and Techniques'
Arnold Gallardo is offline
Old January 25th, 2007   #15 (permalink)
Arnold I have t 2GB, I think you said you have also...?
I dont have internet currently at home so thats a bit of a problem...anyway I thought of an idea. Will try it today a let you know what happens
Beeeee!
del82 is offline
Old January 29th, 2007   #16 (permalink)
Well tried every possible combination and ended up with nothing.
Ls chrashed every time and reports memory error.
I read somewhere that you should at leat have like 2 or 3 times memory then you ls. files is.
I tried removing my memory plates and left just 512 Mb RAM, Then tried to opne ans 430 Mb ls. files.
Ls strugled and didnt sucseeded. It came to around 85 precent and then the HD staretd working like mad (I think due the VR memory)
My VR memory is set to around 3 GB and yes I have empty space on my drive.
I left it for around 15 min to see if It would sucseed but I didnt. But it didnt crash!
Then I tried with another idea of rendering aou tga. file with alpha enabled, then imprten the pictures in Premire and it fit quite nicely.
But then if you look at the picture I have this "BEAUTIFUL" black stich coming egsactly where the two sections connect
This stich isnt there if I merge the geometry and then render the view file. So the geometry if perfectly alinged and there are no gaps what so ever.
Is this maybe due the AA? Because I dont get why this apperas and how to avoid it. But I tried even with AA on 10 an same thing happens every time.
Beeeee!
del82 is offline
Old January 31st, 2007   #17 (permalink)
I was able to merg most of the fies expect the P1 merged. I dont know whats up with that one. Everything else i was able to merge. Also I was able to merge the P1 mergem X2 and kurac with no problems but i cant add the PART2 and PART 3 to that.
You need to send me the original UNMERGED version you have of the P1 .ls files.
Arnold Gallardo
Technical Writer
and Techniques'
Old February 1st, 2007   #18 (permalink)
I made some tests and changed my parametar settings and came up with very nice reuslts.
Also the files where 2x smaller in size . I have one more to go and then the MERGING part.
Check your mail
Beeeee!
del82 is offline
Old February 1st, 2007   #19 (permalink)
I checked email nothing ! Anyway I am glad you got something worked out.
Arnold Gallardo
Technical Writer
and Techniques'
Old February 11th, 2007   #20 (permalink)
Indonesia
Introducing my name is agus
i usually radiosity like this :
"lsrad -cpt 5 -termp 90 -v filename.ls"
save is bat file (namefile.bat)
and save in Lightscape\bin\filename.bat
thanks
agus
papatong is offline
Computer Problem? Need Help? Check Here First! Greg Hess Hardware and Technical Discusions 7 August 22nd, 2008 05:38 PM
File Link Problem... demo38 3ds Max 0 April 13th, 2005 10:50 AM
lightscape cutouts problem :-( cashcb Lightscape 1 February 5th, 2005 08:36 PM
large LP size crashing LSRAD Arnold Gallardo Lightscape 13 July 8th, 2003 09:24 PM
