Old June 28th, 2008   #6 (permalink)
Richard McCarthy
Richard McCarthy's Avatar
Default Re: Display aspect ratio
Originally Posted by RAYMOND View Post
well, looks like res is the answer
however my screen is 14 x 9 (not that huge i guess)
but the res setting 1280 x 1024
which is not the same ratio.
not sure how one get ratio's the same
which would make squares squares
r
Sounds like a hardware problem. What brand is your monitor? Normally, you don't need to install driver for monitor - it should just work properly out of box, let you pick the correct resolution. If you have a wide screen monitor, set it to the HIGHEST NATIVE RESOLUTION (should be in your monitor manual under hardware specification section).
Basically, it sounds like you have a wide screen monitor, but you run it in the incorrect 4:3 resolution hence it makes circle looks like ellipse. If you set it to the correct native resolution (either 16:9 or 16:10), it should be the proper perfect circle, and square will be square.
Some proper 16:9 resolutions :
1280 × 720
1366 × 768
Some proper 16:10 resolutions :
1280 × 800
1440 × 900
1680 × 1050
1920 × 1200
2560 × 1600
http://en.wikipedia.org/wiki/Computer_display_standard
Don't mess with my hat !!
Richard McCarthy is offline   Reply With Quote
