Re: Reading an architects building plans, any pitfalls?
One of the things you may find is that the drawings aren't perfect; i.e. things in different views may not line up correctly, such as windows in plan may be in a differne tplace to the elevations etc. We recently had some drawings where there were a lot of errors with windows lining up on different floors etc. It's not a massive issue, but there will be time when you either have to ask the architect which is correct, or make a decision yourself...
Anyway, if you are modelling in MAX, I'd import the drawings, and get them lined up. Then you can start tracung the walls with splines etc. I personally model all architectural models in Autodesk Architecture and tweak the models in MAX for output..
Keep us posted on your progress...
