Old June 30th, 2008   #8 (permalink)
cebas
Default Re: psd-manager experience
Originally Posted by Trick View Post
psd-manager does not work well with vray opacity maps (multiple layers on top of each other...changing Max transparency settings does not work either)because of the way the buffers are calculated in vray. Even vray's own multimatte element does not work with them.
This sounds like (but may not be) a common issue were you are not increasing the Gbuffer layer amount enough to accommodate for the opacity. I believe if you raise these then all should work well. If this is not the case please do post your issue with a simple scene on our support forum so that we may get it straitened out ASAP (If we can.. May just be lack of Vray support for real Gbuffer info).
I would highly recommend asking about this (and any other questions) on our forum. Our developers are very helpful and fast to respond as well as the psd-manager user community.
Thanks a bunch
Michael McCarthy
cebas USA
cebas is offline   Reply With Quote
