Old June 30th, 2008   #4 (permalink)
oluv
oluv's Avatar
Default Re: Realtime for Sketchup
i had a look at the youtube videos and the results are looking quite impressive, especially for sketchup.
so when you say that the lighting is applied as a texture to all the objects, how is the unrwapping process handled? does it produce one single texture for all objects or one texture per object? also am i able to define resolution of the resulting lightmaps? will it produce bigger textures, the more faces i have or will the accuracy decline the bigger my models become?
thanks again for your comments and best regards, olaf.
oluv is offline   Reply With Quote
