Originally Posted by oluv
i had a look at the youtube videos and the results are looking quite impressive, especially for sketchup.
Ouch, faint praise there!
Sketchup is doing something there that Maya/Max/SI etc just can't do..
so when you say that the lighting is applied as a texture to all the objects, how is the unrwapping process handled? does it produce one single texture for all objects or one texture per object? also am i able to define resolution of the resulting lightmaps? will it produce bigger textures, the more faces i have or will the accuracy decline the bigger my models become?
LightUp handles the processing and lighting. Its very flexible in controlling resolution; if you really need to sample lighting every 4.5cm, you can, or you can let LightUp figure something reasonable and modify it. It handles groups and components too.
Adam
