Old June 30th, 2008   #9 (permalink)
RAYMOND
RAYMOND's Avatar
Red face Re: Display aspect ratio
Originally Posted by AJLynn View Post
Where you set the monitor resolution in the Display control panel, under Settings. Drag it all the way to the right. Alternatively, look up your monitor's resolution, and set it to that.
the settings are all the way to the right
however how can setting be reset to the monitors res
the menu says 1280 x 1040 which is the same as the properties
see no way to do that in display properties...
also tried the menu on the monitor itself... but all one can do is just align the display...still ellipeses for circles
maybe it be the driver...
r
RAYMOND is offline   Reply With Quote
