Old June 30th, 2008   #5 (permalink)
Superfinicky
Default Re: 3D Gallery for architects and designers
Hi Brian,
No the site is a collection of existing models, again direct from the manufacturers. There are some custom/bespoke pieces out there as well. Every object is individually linked to the corresponding manufacturer and the manufacturer's tech spechs are used.
I admit that the gallery is not at its peak yet, far from it [content-wise] but the pieces that are up there are quite detailed. For more previse examples, check out the decorative hardware levers, faucet sets, and some of the ironwork. The renders on the site are literally 5 second 3DS renders without any mapping or textures applied. The actual pieces are high poly, high in detail.
The site's backbone for now will be architectural hardware, lighting fixtures and ironwork. This is a painstaking process, as you can imagine the work that goes into each individual piece. Again each and every piece in our galleries are manufactured by the designated manufacturer. We also offer rapid prototyping services should you require it. From 3D design to resin sample, or bronze, or whatever you require the end piece in.
BTW...you can sign in to the archi/deco part of the site using demo for both the username and password. Check out the galleries and let me know what you think. If you are concerned about detail, I can give you a free download to check it out.
Thanks again for your input.
Best,
Ori
Superfinicky is offline   Reply With Quote
