3ds Max Autodesk 3ds Max
Old January 11th, 2007   #1 (permalink)
guitarboy's Avatar
Australia  Send a message via MSN to guitarboy
Default Alpha Channels/Maps
G'day, i fairly new to the 3d scene and have been having a little trouble getting nice backgrounds in my renders, and have been told to try using a alpha channel/map for my back when i render in max/vray and then move that render into photoshop and place my background in there.
My question is how do i actually get an alpha channel/map in for my background? and are there any other special things i need to be aware of besides that i need to save my render as a .tiff file format or similar in order for the alpha to work?
many thanks
guitarboy is offline
Old January 11th, 2007   #2 (permalink)
Horhe's Avatar
Default Re: Alpha Channels/Maps
What you need to do is to get a render from your 3ds max without the background (without the map that you have in your enviroment slot - either a image file or just plain color). The rest is done under PS as you correctly stated.
many thanks
Yes there are. Firstly you do not save your image as .tiff. That'll do you no good. The file extension that seperates your scene's models and the background is the .png, which you will obviously find in the save image rollout menu.
In more detail, what happens when you save your render as .png, you get an output of your render with the enviroment or (background if you prefer) transparent. So when you load it up in photoshop you will have the image in the layer without the background jus like i said - transparency.
To input a background, simply place the recieved render on a layer above the backdrop image, so that the transparent bits of the image show the map.
Have fun
www.JakubGabriel.com
| DoodlesWhileCookingNoodles
Horhe is offline
Old January 11th, 2007   #3 (permalink)
guitarboy's Avatar
Wow, thanks for such a quick and in depth responce.
so if i just leave my render environment as the standard black, and save my render as a .png, that should work?
Old January 11th, 2007   #4 (permalink)
Horhe's Avatar
You can leave your render enviroment any color you like, black yellow brown or a bitmap if you like. Its not taken into account when outputting as .png, but probably is with global illumination calculations and reflection/refraction unless you are overiding them with a map somewhere else in the gi settings.
Horhe is offline
Old January 11th, 2007   #5 (permalink)
guitarboy's Avatar
AWESOME, thanks so much, i cant wait to give it a go. Your a champ
Old January 11th, 2007   #6 (permalink)
guitarboy's Avatar
i just tried it out and it worked perfectly, thanks heaps again.
Old January 11th, 2007   #7 (permalink)
Horhe's Avatar
No probs glad i could help, post it up when youre done
cheers mate
Horhe is offline
Old January 11th, 2007   #8 (permalink)
guitarboy's Avatar
No worries, i just need to find some decent backgrounds. Do you guys get them off the net, or take your camera places and take your own pics, or something differnet again?
Old January 12th, 2007   #9 (permalink)
guitarboy's Avatar
Gday, ive just moved my render over into PS, but ive noticed ive lost all my reflections in my window doing things this way, is that meant to happen, and is there a way around it???
alpha grayscale problem, help 3dSol General Discussions 6 December 14th, 2006 02:21 PM
using stored alpha channels ....how? haneet khanna 3ds Max 6 April 11th, 2005 12:15 PM
TIF and saving alpha proces2 3ds Max 0 March 31st, 2005 03:56 PM
compositing in photoshop with alpha channel Munz Photoshop 4 November 16th, 2004 06:00 PM
Alpha animation into Premier 6.0 Wokka Compositing Software 6 July 12th, 2004 03:35 AM
