Re: REVIT 2009 and Ghery style
Originally Posted by AJLynn
Rhino would also not be the right tool for the job unless you are a brilliant script writer. All due respect, Jonas, but I very strongly doubt you've done this. We're talking about thousands of metal panels, all different, with the hardware for mounting them and the structure that supports that. Each dimensioned and at a precision where you can get a shop to fabricate not a model of the building but the actual building. All of this is constrained by lord knows how many variables. The parts aren't modelled, they're defined parametrically and computed, and the casual user is not going to be able to do this.
go get the panel plug-in that was split from the archcut plug in and be proved wrong
yes you can make scripts to do more advanced panel shapes but the ability with out knowing so much is totally accessible available and FREE
http://en.wiki.mcneel.com/default.aspx/McNeel/PanelingTools.html
UPDATE: a new version of Panel Tools came out (minutes) after i posted this
