Old July 1st, 2008   #3 (permalink)
Justin Hunt
Justin Hunt's Avatar
Default Re: First Interior Rendering in Mental Ray - Please Help to Improve
Just looking at your sun settings, a couple of things
1) The photon Target is way too small, it should be just large enough to fit the windows, ruff guess 15 - 20 meters
2) turn Off aerial Perspective, this is better for (as its name suggests) aerial shots where you want a bit of fog/distance haze on the horrizon, not so good for interirors.
3) Increase the sun shadow softness to clean up the shaow edge grainyness
Exposure control
1) Turn Off exterior daylight, you may need to play with the physical scale
GI
1) Increase the photon sampling radius, try 200 - 500mm
2) Increase the Max trace Depth, gets more light bouncing around , you may need to compensate with exposure control
3) leave Decay at 2
4) Turn On "All objects generate GI"
FG
1) increase the interpolate to 80 -100 smooths out the blotchies
2) Noise filtering to standard, anything higher slows down rendering too much
jhv
