July 1st, 2008
#4 (permalink)
Re: First Interior Rendering in Mental Ray - Please Help to Improve
Hi Justin,
Thank you very much for your time and valuable input. I will test these settings you've recommended as soon as I get home. Just a few questions:
Originally Posted by Justin Hunt
Just looking at your sun settings, a couple of things
1) The photon Target is way too small, it should be just large enough to fit the windows, ruff guess 15 - 20 meters
Would this matter if my scale is 1:1mm. By increasing it to 15-20 meters, would that be really huge?
2) turn Off aerial Perspective, this is better for (as its name suggests) aerial shots where you want a bit of fog/distance haze on the horrizon, not so good for interirors.
Of course. Will do.
3) Increase the sun shadow softness to clean up the shaow edge grainyness
Will do.
Exposure control
1) Turn Off exterior daylight, you may need to play with the physical scale
I only have the daylight system ( mr sun & mr sky ) as light source for this scene. Does that mean I have to increase the physical scale higher than what I currently have?
GI
1) Increase the photon sampling radius, try 200 - 500mm
Are you pertaining to Volumes: Maximum Num. Photons Per Sample?
2) Increase the Max trace Depth, gets more light bouncing around , you may need to compensate with exposure control
Should I keep Max. Reflections & Max. Refractions the same?
3) leave Decay at 2
4) Turn On "All objects generate GI"
FG
1) increase the interpolate to 80 -100 smooths out the blotchies
2) Noise filtering to standard, anything higher slows down rendering too much
Yeah. I just figured it will make things smoother but almost none have changed.
jhv
What about Photon Map and FG Map? Do you think it is much better to do freezes/saves? I find it a little bit troublesome doing it and it works pretty well without it. What do you think?
Thank you very much I'm sure these will definitely help.
