Old July 2nd, 2008   #12 (permalink)
Justin Hunt
Justin Hunt's Avatar
Default Re: First Interior Rendering in Mental Ray - Please Help to Improve
FG/GI Freeze, absolutly, if you generate the FG GI at half the final res, freeze and re-render at full res is quicker than FG/GI at full res. Dont go too small though. Although for testing dont bother.
Photon tagret - this has nothing to do with the size of the photons but rather the area where the phtons first hit. Think of it as a tube down which the photons are shot. At the moment the photons are focused on a pin head, and I would hazard a guess that most of the scene is being light by FG rather than the photons.
The exterior daylight is for exteriors, behind the scene mathermatics are adjusted by this toggle. For interiors try physical scale of 1500+. If you have max2008 or higher use mrphotographic exposure instead. Not too sure if Viz2008 has it though
Photon sampling radius controls the detail of the illumination by photons, small radius ->more detail -> more photons, larger radius->smoother/less detail->fewer photons. its a balancing act to find the right numbers
Leave the max reflection/refraction as is, these control how the lighting solution looks in refections and refractions, play with these if you have errors in the reflections/refractions
anyone please correct me if I havn't explained properly
jhv
