hi to all,
I want to knw that if i am saving my irradiance for 0 to 100th frame in one file and saving 100 to 200 frames in another file. After saving if i launch these two seprate files on net render with giving path for iradiance map resp. then will it gves me the diffrence between these two renders, means any GI flickers or shadow flickers. if anyone knows about it pls help me . its an urgent .... Thanks In Advance. Thanks Yogesh |
Name: Christopher Nichols |
Man... you have a lot of urgent issues all the time...
You need to merge the two maps together. I suggest you use the Irradiance map viewer load in one map, then do a file merge with the other one, then save out a new one. Use the new one on the farm.
Christopher P Nichols |
#3 (permalink) | |
thanks chris, franckly speaking right now i am on so much pressure and having deadlines to meet, right now i have 2000 frames animation and i don't have so much time to calculate irradiance ,.. so i have calculated those diffrently ,, i studied your DVDs i know we can merg those frames. But for that i think i have to calculate for all of my frames and then i have to merge them right. i thought if i am calculating 200 frames like this then i can launch for farm and by the time i will calculate for remaining. Really i m in the high time chris..... letc hope for the best... thanks again Yogesh |
Name: Vivek Punjabi |
Yogeshwagh,
why dont you post in the official Vray forum? A lot of your questions may already have been answered there, and the guys there are always ready to help. Its helped me tremendously! Vivek |
| Problem with Irradiance map multiframe incremental urgent pls help.... | yogeshwagh | VRay Render | 22 | July 25th, 2007 08:54 AM |
| irradiance map.. | shikodesign2000 | VRay Render | 1 | December 16th, 2006 09:31 AM |
| Irradiance Map in animation | FlytE | VRay Render | 4 | June 21st, 2006 07:54 AM |
| Is Saving Irradiance Map Helps Lower Rendering Time? | odi120522 | VRay Render | 2 | April 25th, 2006 12:10 PM |
| Light catch map and irradiance map corrections | naominch | VRay Render | 1 | March 7th, 2006 06:21 PM |
