Old July 2nd, 2008   #2 (permalink)
TheAllusionist
TheAllusionist's Avatar
Default Re: Field Grass using Hair and Fur
Haven't tried it since Max 9 so I am not sure if it will work with current versions, but you might try SuperGrass http://www.antiflash.net/supergrass/
And the all knowing mr guru Jeff Patton has an older tutorial http://jeffpatton.net/MR_Grass_displacement.htm
The Opinions Expressed Here Do Not Necessarily Reflect Those of a Rational Mind.
3DAllusions | 3DAllusions Studio | MrMaterials
TheAllusionist is offline   Reply With Quote
