Old January 15th, 2007   #1 (permalink)
Mexico
Default Vray animation render problem
I made an animation with vray but i have troubles. I render a frame and looks great, now i followed a tutorial of vray to make an animation but i see the tutorial works only to moving scenary and static objects. In my scene i have a white moving object and static scene and the shadows looks strange, noisy and only in the moving object. Then i followed the tutorial of vray of render animated models with qmc but now the render take 1 hour in render each frame. I had render times of about 2 mins per frame and with qmc 1 hour. I wanna know if someone can help me in configure qmc with best settings and fast rendering like irradiance map and good quality. Or use irradiance map in moving objects wiht no nosy problem. The strange is if i have an static objects and a camera move only the aniamation looks pretty only in moving objects have trouble. I appreciate so much
field3d is offline
Old January 15th, 2007   #2 (permalink)
ershad's Avatar
Name: ershad rahbar sobhkhiz
Iran
Default Re: Vray animation render problem
dear friend :
my offer is : rendering your scene in several Layers
1: back ground (were you have still object)
2: foreground (were you have Dynamic object )
3: shadow layer (this is very important layer and you must render this layer by maximum of sample )
you can separating layer with (vrayspherefade60) and then composite all
kind regards
PIONEER
ershad is offline
Old January 15th, 2007   #3 (permalink)
Mexico
Ok any tutorial in how to redner by by layers, or to do the same you are telling?
field3d is offline
Old January 15th, 2007   #4 (permalink)
ershad's Avatar
Iran
ok you can find the TUT file and some tools in this address :
http://www.spot3d.com/vray/help/VRayHelp150beta/
PIONEER
ershad is offline
Old January 16th, 2007   #5 (permalink)
Hai,
check whether this helps you... i did it once when i faced the same problem...
hide the moving object while calculating the irrandiance map.. and unhide the the moving object while rendering.... but the render time will be increased by 1 or 2 min for each frame....
sam
ksampath is offline
render strips using vray frame buffer seamus VRay Render 3 July 24th, 2006 08:29 AM
Vray Glass Problem Hallock VRay Render 8 June 14th, 2006 08:37 AM
Help Vray Animation gods418 Work in Progress (WIP) 14 May 29th, 2006 04:03 AM
Vray Plane problem frazer VRay Render 2 May 5th, 2006 04:32 AM
Vray Animation - Please Help! stylez 3ds Max 7 May 24th, 2004 11:31 PM
