Re: "No Video" on new PC
I think the problem is with you TV. Try booting up the computer again without it hooked up to the TV and once you think the computer is fully booted up plug it back into the TV again. Also your computers resolution has to be set to a resolution that the TV can understand. You should check your TV manual to see what this is.
It would be good to if you had a old monitor around so that you could check it this way.
"Its so easy to be critical"
