Just make sure that Mental Ray is set as your render engine. The MR specific stuff won't turn up if it's not selected. Other than that, use my generic Everything-is-a-nail-and-the-only-tool-I-have-is-a-hammer fix:
weird problems with the interface??
Blow away (or rename) 3dsmax.ini
C:\Documents and Settings\[USERNAME]\Local Settings\Application Data\Autodesk\3dsmax\9 - 32bit\enu
Man, I should update the path in my notes...
