Old January 16th, 2007   #1 (permalink)
Name: Estyl De chez Estyl
Austria
Question Using merged model's Vray materials in your current Material Editor
Hi,
I would like to ask you, how it is possible when I merge an external model with my current scene to make his vray materials appear in my current material editor.
Until now I was using the "pick material from Object" tools on each new material to make them appear on free slots in my material editor.
This time I have more than 15 materials and the procedure is a way to long.
Am I doing something wrong ?
Estyl
estyl is offline
Old January 16th, 2007   #2 (permalink)
erickdt's Avatar
Name: erick gustafson
Default Re: Using merged model's Vray materials in your current Material Editor
If you click on the "get material" button in the material editor there will be an option to click on "scene" where "material library", "material editor", etc. are located. Once you click on that a list should come up of all of the materials in the scene. Double click on the one you want and it will show up in the editor under the slot you previously selected.
erickdt is offline
Old January 16th, 2007   #3 (permalink)
Austria
Thanks a lot Erickdt, you cannot imagine how much this helps !
estyl is offline
Vray Backlit material philip kelly VRay Render 2 January 9th, 2007 10:31 AM
vray material over bright warning aligrafix VRay Render 0 August 24th, 2006 01:40 AM
Vray Material Library yogeshwagh VRay Render 12 June 17th, 2006 11:57 PM
self iluminated material in vray Juliano Rocha Autodesk VIZ 5 July 19th, 2003 05:51 AM
vray material proces2 VRay Render 11 July 9th, 2003 10:24 PM
